Porsche, and the Porsche crest are registered trademarks of Dr. Ing. h.c. F. Porsche AG.
This site is not affiliated with Porsche in any way. Its only purpose is to provide an online forum for car enthusiasts. All other trademarks are property of their respective owners. |
BillC |
Post
#1
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Found one. Thanks! |
JOEPROPER |
Post
#2
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() |
JeffBowlsby |
Post
#3
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,005 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I have the mounting plate for you. Will PM. Looks like the above poster has the grommets. Screws are easy to come by.
BillC |
Post
#4
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? |
JOEPROPER |
Post
#5
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. |
BillC |
Post
#6
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. @ JOEPROPER PM sent. Thank you very much! |
G e o r g e |
Post
#7
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
FlacaProductions |
Post
#8
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,984 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
914Sixer |
Post
#9
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,220 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
The ones I was selling OEM later Bosch without the bass center. MIGHT have some used ones. Have to look.
FlacaProductions |
Post
#10
Very good - see you see. Thank you!
Lo-Fi Version | Time is now: 15th August 2025 - 06:05 PM |
All rights reserved 914World.com © since 2002 |
914World.com is the fastest growing online 914 community! We have it all, classifieds, events, forums, vendors, parts, autocross, racing, technical articles, events calendar, newsletter, restoration, gallery, archives, history and more for your Porsche 914 ... |
